Kasey
Has anyone ever attempted to build a "split single engine" using the same principle as employed in a Daimler Puch 250cc SGS twin motorcycle engine?
model engineer had plans for one you may be able to search back issues on lineHas anyone ever attempted to build a "split single engine" using the same principle as employed in a Daimler Puch 250cc SGS twin motorcycle engine?
THANKS, I'LL TRY TO FIND IT. At present I'm making a mock-up of a flat four of 340ccs based on a Victa twin 170cc mower, boxer engine, using its crankshaft and pistons x 4, via my 3D printer making the plastic cylinders, heads, double con rods etc. It's slow work but interesting. If it turns out ok, I'll get the thing cast in aluminium for a running engine.model engineer had plans for one you may be able to search back issues on line
as you are talking to a small engine tech this is getting very interesting indeedTHANKS, I'LL TRY TO FIND IT. At present I'm making a mock-up of a flat four of 340ccs based on a Victa twin 170cc mower, boxer engine, using its crankshaft and pistons x 4, via my 3D printer making the plastic cylinders, heads, double con rods etc. It's slow work but interesting. If it turns out ok, I'll get the thing cast in aluminium for a running engine.
these are a couple of briggs and tecumseh engines i have built thought you might like to see
Not yet but....The porting here can be rather interesting as the overlap between the 2 pistons at BDC allows for them to be open longer and still open even when the exhaust port has become fully closed. Thus it means almost 100% of the incoming charge cannot get anywhere near it in exhaust cylinder. That and the con rod angles at ignition are what give this type of engine tremendous torque compared to standard practice at ignition, which has only a few degrees of leverage on the crank.Did you ever find the plans for the split single. I have researched them quite a bit but have never found plans for one.
I am in the process of designing a single 2 cycle just to better understand the functioning of the ports better but my goal has been to build a "twingle".
Want an unusual project? Try this one. Honda in the 80's made Formula 1 and Motorcycle racing engines with OVAL pistons! Here is a Vimeo video of what they looked like.
Grasshopper
