Hardness tester
SmithDoor
Staff member
Global Moderator
Clovis Ca
Simple hardness for material hunting.
Leave no marks
This is Simple a stick 12inchs long or 300 mm like paint stick.
And a copy of page wrap around stick for marks. .
I have bag if 3/8 hardened balls. So if loss one anc more to use.
I have different one for shop use a 3/16" balls for thiner gauge.
  • HARDNESSTESTER Hardness (3) (1).pdf
    261.4 KB
I have seen one backyard casting person obtain a ball-type hardness tester, and he seems to get accurate results with it, as far as testing his iron castings for chills and hard spots.
I had check class 45 cast iron and would not fit in Rockwell tester.
Rutland had a unit for none destruction testing I purchased and very simple . A 3/16 ball from ball bearings. And a clear tube . It work but easy to lose the small ball so I up size so easier to find the ball. Then used a paint stick good and bad marks . Now my crew could check the hardness too. They set wheel on floor and drop ball. In time a rug around the wheel stop ball from hiding . The pickup ball and check next wheel. We did not check every wheel just in in each batch.
Then when looking materials it came handy too.
FYI I still have the test disk from Rockwell hardness test I think last for ever
Do you have to use a 9.5 mm ball with the metric version ? <big evil grin> Thinking of the metric adjustable wrench cluster :cool:
Actually quite a neat way to get low cost hardness testing into our world, thanks for posting this! I'd seen the vacuum column ball drop style in the past but not the linear scales to make it so easy.
