Hand Collet Closer for Clausing 5904
Drew
Active Member
Rolling Meadows, Illinois
Hello,
I have an old Atlas Clausing 5904 lathe. It works well, for the most part, but I have had a hard time finding some items for it. Particularly a collet closer. The lathe has a 4.5 Morse taper in the spindle nose.
I have seen pictures of a 5C adapter for this taper, but haven't been able to find one.
So I decided just to make one, along with the rest of the thing.
I bought a replacement draw-tube on E-Bay, long enough to cut down.
I had a tool steel round and I grabbed a piece of scrap aluminum from work.
First I drilled the round on the lathe then cleaned up the end.
Next I figured out the approximate length and Ø I needed for the taper end.
After turning it close to the large size, I calculated the taper and set my compound using a dial test indicator.
The tool was repositioned and the taper carefully cut, finishing to the high side of what I needed.
From there a little judicious sanding and I had a really nice smooth taper. Also finished was the shoulder and major diameter beyond the taper.
I proceeded to remove the chuck and carefully wipe the spindle nose and bore. then lightly sanded some minor dings out and installed the adapter.
A quick check with the indicator to ensure squareness and concentric of the seating.
Next I bored it out to accept the 5C collet, then setup the compound for 9.5 deg and cut the angle back far enough to get the collet where I wanted it. Then I trimmed off the face and chamfered the edges.
I checked the length of the tube against the fit of the sleeve and cut it off with enough for adjust ability and
width of a handle.
Cleaned up the end, turned the OD and treaded it.
Next I turned the handle. Starting with the face then hole and thread.
After verifying the thread fit with the tube, I preceded to kind of freehand the rest of the handle.
Here are some pictures.
Thanks for letting me share.
No thanks required. We in fact, thank you for sharing. Ideas generate more ideas so we are the winners.
