I made my disk that holds the magnets out of steel and the engine runs just fine. Others have made the same part from aluminum with no noticeable difference in performance.
I have used 2D CAD for many years--believe me, 3D CAD is actually much easier if you get the right CAD. My son uses Fusion but I tried it and it was more difficult for me to use than to continue with AutoCAD Architectural for mechanical parts. Yes, it works just fine for mechanical too. However, I have used many 3D CADs and they are usually much easier to use than 2D--Really!I don't have a specific engine at this point. This is what I found on Thingaverse which I used on a previous engine. It worked but it was really too big and I ended up cutting the mount lugs off and tapping into the body. I had not really thought about epoxying the sensor to a brass or aluminum plate. That would actually work well since the actual mount changes with each application. One of these days I am going to have to get serious about learning 3D cad. I have used 2D cad for years and they say that makes it harder to learn 3D. I have played around with Fusion 360 and Freecad but by the time I need them I have forgotten too much and end up spending hours trying to relearn stuff.
I suspect that had I been using Autocad I would be better able to transition to 3D. I have been using Visual CADD for 30+ years which uses 2 letter commands instead of menu items. It is primarily a drafting program. It enters values in x/y coordinates. For example I can snap to a given point and enter a command like C2 which is a circle defined by radius. It will ask for center point which can be entered as x,y (example 3,2 where it is 3" in x direction and 2" y direction) then it asks for the radius and it produces a circle. You can use the menu but once you learn the commands it is much faster than finding items a couple of items down in the menu. At 80 years old I do not want to spend a lot of time trying to learn an new program for occasional hobby use.I have used 2D CAD for many years--believe me, 3D CAD is actually much easier if you get the right CAD. My son uses Fusion but I tried it and it was more difficult for me to use than to continue with AutoCAD Architectural for mechanical parts. Yes, it works just fine for mechanical too. However, I have used many 3D CADs and they are usually much easier to use than 2D--Really!
You don't look 80. If you can get a copy of Inventor, an old copy, it is exceedingly easy to learn. Follow the tutorial, learn it in two days or less.I suspect that had I been using Autocad I would be better able to transition to 3D. I have been using Visual CADD for 30+ years which uses 2 letter commands instead of menu items. It is primarily a drafting program. It enters values in x/y coordinates. For example I can snap to a given point and enter a command like C2 which is a circle defined by radius. It will ask for center point which can be entered as x,y (example 3,2 where it is 3" in x direction and 2" y direction) then it asks for the radius and it produces a circle. You can use the menu but once you learn the commands it is much faster than finding items a couple of items down in the menu. At 80 years old I do not want to spend a lot of time trying to learn an new program for occasional hobby use.
The reason that I don't look 80 is because I will not be 80 for three more weeks.You don't look 80. If you can get a copy of Inventor, an old copy, it is exceedingly easy to learn. Follow the tutorial, learn it in two days or less.
I use a very old Inventor, I thimk it is version 6. It is really great, not perfect but does great stuff. I thimk I will try to find the Alibre that Mrehmus mentions above.The reason that I don't look 80 is because I will not be 80 for three more weeks.
Inventor software situation is interesting. I looked on Amazon and it is super expensive and they only seem to have 2020 version. Prior year versions are no longer available but the description says that it is downloadable in 11 hours on broadband and 433 days on dialup. Imagine having a dedicated phone line tied up for over a year and then having a power outage on day 432 and starting over. I looked on eBay and there are student copies available for $15 to $25. They state that the sellers are students who are eligible to purchase the student edition but they have not used them so they sell their copy on eBay.
I'm dislexic, did you say 08? I'm 17. I lookt up Alibre's 3D. It lisenses for 200$US which is really a good deal, it is perpetual, you can -put it 9on more than one computer but the liscence code is only good for one computer at a time. Mrehmus says sometimes it goes on sale. I wonders if they give senior discounts.The reason that I don't look 80 is because I will not be 80 for three more weeks.
R u able to get updates or are you still using the orignial from 15 years ago? Maybe a newer version would be more powerful.No, the software is around $150 and sometimes for sale for $100. It is not perfect software but I've been making models and drawings with it for 15 years since I started the magazine.
I've used Solidworks professionally, it is really easy and powerful. Maybe I will go to school in Astronomy (want to make a couple mirrors for telescopes) and get the Solidworks for 20$. Thanx for the heads up.If you really want to step up to the 3D plate and are a student or veteran (US & Canada, maybe others) you can get a 1-year license for the full Solidworks for $20. You have to buy another $20 license after that year.
I'm either too old or too lazy to learn another program since Alibre does everything I want (even though the support fee is $465 a year for the top-end version) which I have.
