Half my split single, flat four,boxer engine, so far.
Kasey
Brisbane,Australia
Have now finished the box crankcase, have had cast one cylinder pair, and had one head machined all without cooling fins so far. as they can be machined in/ fitted on later.
The magneto is fitted with a good spark. as is the carbie and reed valve. As this is as intended, half a flat four, based on a Victa flat twin, I'll mount it on a ordinary mower base for a test run. Hope the balance (from a Victa single crank) is OK, however, but which should improve in flat 4 mode. The other side's cylinders and head are in the process of making now, so I hope it can then advance to a real flat four of 34o ccs. for a test run.......Eventually, maybe on an outboard motor leg unit or motor cycle?
    120.7 KB
