- May 27, 2010
- 2,999
- 1,171
Looking good Gus, I ended up using lead solder on my tank after having trouble silver soldering the first attempt.
Paul.
Hi Paul,
I cheated. Only the fuel socket was silver brazed. The trick is you need fire power. I first use a Butane torch to dry uo the flux paste and preheat for a while then use a two burner Mapp Gas Torch. Must heat up the brass nozzle to
dark red heat with the copper pipe and then heat up the silver rod before apply to the joint area. The molten silver rod will melt like ice and flow all around. Some additional silver may be required to to thicken up joint.The Permanent Marker was use to contain/prevent spill over.
The two end caps were drive fit in with lead solder rod in a circumferential groove to melt inside w/o spilling out. Temperature is by eye-ball judgement.
The trick to good silver brazing is sufficient heating power to reach brazing temperature quickly and no over heating.Dark Red will do.
Was lucky this occasion to have done a good looking joint.Been taught by a refrigeration plumber who made silver brazing look so easy.
