Naiveambition
- May 15, 2012
- 369
- 95
i am setting up a grinder station to grind my tools and have ?s regarding wheel types used.
First off I will be grinding lathe bits, drills, and possibly endmills. I have the Harold hall grinding jig book on the way to help with angles.
My question is more of what kind of wheel to use. Meaning cup, plate mounted, regular flat face.
The drill sharpener says to use the side of the reg. wheel, and while this may be ok by somewhere else, I am wildly uncomfortable doing this. I'm sure the front face would work with a rigid setup to eliminate flex, but if it ever does catch their will lots parts and pieces a flying.
So pre thought would be a plate mounted wheel to do drills, (prob. Alum oxide) and hss lathe tools. And a green for lathe carbide.
Am I correct that u only use the face of a plate mount wheel?
And as for endmill sharpening I'm guessing a diamond cup wheel, I may want to sharpen the side flutes later on as I get through Harold's book, but for now just the face.
