- Dec 31, 2010
- 812
- 215
I'll ask this question here because I'm sure you are all aware of this method of making a cam:
Take a cam blank,hold it horizontally in a rotory table,
Rotate it a number of degrees, lower the cutter a pre-determined amount,
Take a flat cut across the side of it, turn it again, lower the cutter some more (or less), take another flat cut across it etc. etc.
In the end you have a rough cam shape with small steps instead of a smooth surface and you then file it to remove the steps.
The amount to turn and the depth of cut can be calculated from a program called CamCalc which is free.
Hopefully you know what I'm talking about.
How about this idea:
Hold the cam blank horizontally in a rotory table (as above).
Arrange a fixed grinder at the back of the milling table with a stone the width of the cam lobe. instead of a cutter (as above).
Advance the table Y axis into the grinding wheel the same amount (as above). The result being you get the flat spot in one touch without having to move across the lobe with a small cutter. No difference from above really.
Now the new idea:
Instead of backing out when you rotate, keep the wheel where it is and rotate the cam blank (as above) the prescribed amount.
BUT if you do this with a CNC machine and GCODE program you can put the rotation AND the depth of cut command (A and Y) on the same GCODE line and you'll get a (somewhat smooth move in both rotation AND depth of cut (Y) at the same time.
This should produce a smooth surface joining the individual points requiring little or no filing instead of rough steps.
Sounds reasonable to me but I can't figure a couple of things and I need some help getting this straight in my mind:
As with any outside profile milling the path taken depends on the diameter of the cutter (I think). Also I know that real cam grinders use master cams that don't look anything like the finished cams and you have to use a follower the same diameter as the grinding wheel.
In this case we have a wheel that is say 4" in diameter. Does that matter?
On the other hand the wheel is only touching the side of the cam blank at one point so does the diameter of the wheel really matter.
I need help getting this straight in my head.
I'm about to try it. I have the Gcode figured out but am I wasting my time?
Sage
Now the new idea:
Sage
