Hi,
Does anybody know where I can find this DVD for under $30 new or second hand.If anybody has a copy of it or know where I can find it , it would be a great help thanks.
'''Graver Making & Hand Turning DVD by Bill Smith'''
Ted,
I don't know how you intend to use these, horology or otherwise, but I made myself a handful of very useful gravers for fine contouring and finishing work on my full size (larger than horological size) lathe. I bought a few wooden handles and a few bits of ground HSS in 1/8" rounds and squares. I ground off one end of the HSS to a 45° (or so) angle and poked the other end into a handle. Then I made myself a sharpening jig and went to work making them frightfully sharp, and they work beautifully. No doubt Bill Smith (a Tennessean IIRC) uses carbon steel, hardened and tempered, and I won't argue that might be better for watch and clock work, but compared with watchmaking my usage could be considered "rough use" so the 1/8" HSS works just fine. The only problem I have is that gravers require high spindle speed for optimal results and a conventional lathe will barely make a workable minimum rpm thus increasing the potential for dig-ins so I work very close to the work.
I'd recommend the Sherline documents - I used them to make myself a set of gravers some years ago and have used them ever since. I will say this, though - you must have a decent T-rest if you plan to use gravers.
That having been said, Bill Smith's books are great stuff - full of little tips and hints that help a lot. I suspect that his DVD's might be worth the money.
You can get them from here: ClockTools.com, but of course, they're more than $30.
I rent often from SmartFlix. I'm usually after the information and learning from the vids rather than owning a set of something else to get dusty on the shelf so it makes sense to me.
I am just about certain that you aren't allowed to copy them, though. (Well... maybe if the copyright has expired? 20 Years I think... and some may be that old?)
