Thanks Mechanicboy !
I'm doing it again. Maybe it would be better...
And much easier if you have a reed valve in the back cover where the carburetor is mounted on back cover since timing is not critical (timing is fully automatic). The reed valve is locked with spring lock ring same as Cox engine to example. The reed valve can be made of plastic sheet or beryllium copper sheet (difficult to buy, then i used the plastic sheet as valve, last very well). Rotary valve in the crankshaft also works very well. If you want to make engine with reed valve, ask me then i give you a plan of back cover with reed valve
Yes, it's this as model glowengine fuel.
