No, not swollen glands.---The other kind, like you see on the end of a steam cylinder or valve chest, where the piston or valve rod exit. I have built about a dozen double acting steam (air) engines now, and up untill the Popcorn engine, I never used glands. Just a reamed exit hole that was a "good sliding fit" on the rod, to prevent air loss around the rod. I didn't use them, because I deemed then as being extra work, and unnecessary for the small models I was building. And there was a third reason, that up untill now I never had actually proven, but had theorized. I openly admit that I am a total Putz at single point threading. Consequently, I create all of my threads using taps and dies. I have noticed several times while threading different sizes of rod, using die holders in the tailstock of the lathe, that the threads I cut were never quite concentric with the rod they were on. I know my tailstock is "centered" properly. I know my die holders that fit in the tailstock are a good fit on the outer diameter of the die, and are concentric. My dies are new and sharp------But still, the threads are always a bit "off".---Do you see where this is going?---I concluded that any gland nut I machined with a reamed hole in the center for the rod and threads on the outside where it screwed into the cylinder or valve body would give me fits, because of non concentricity issues. And I was right!!! My Popcorn engine runs like a charm on about 15 PSI unless I snug down the gland nuts. IF I snug them down, it takes 60 PSI to run the engine------and its all because of my theorized non concentricity issues. Perhaps I'm going about this wrong. I don't have any packing in the glands right now, so maybe if I can figure out what to use for packing, the gland nuts don't have to be tight enough to cause me a problem. I would like to hear some input and advise from other model engine builders on how they handle this issue, please.----Brian
