I was in contemplative mood and playing with my hypocycloid engine and wondering what else I might - as an engineer - accomplish with its strange motions.
See prior Hypocycloid :-
Hypocycloidal Engine
It suddenly dawned on me that any point on the PCD of the pinion gear will describe a straight line - but in a different direction than the piston stroke.
Therefore the motor could be made to work using a series of pins or rollers running in a series of straight grooves.
This I thought, might be handy for those guys who perhaps wanted to build a hypocycloid but were put off by the need to make a decently accurate annulus and pinion gear set. Particularly as there is no easy way to fix it if runs tight or binds up.
The pin and groove method I am suggesting can be readily relieved as much as is required to get it to run,
This is the GA
This is the principal difference between this and my prior Hypocycloid.
The left hand images are of the prior annulus gearset and to the right the "gearless" version.
Thanks to the ever helpful efforts and 3D animation wizardry provided by JonMCC69 the following video shows it demonstrated as a feasible model.
John's wonderful animation also shows off the action of the "D" valve and its timing.
Caution: Whilst I have provided the plans below, I have not yet built this model (but I have started).
There is an A0 pdf print and the zip file contains an ACAD.dwg file.
Regards, Ken I
This is the GA
Regards, Ken I
