I have just ordered a copy of "Gears and Gearcutting" by Ivan Laws.
kuhncw said:Perhaps it's been mentioned and I missed it, but 20 and 36 tooth gears can be cut using a 5C spin index to do the dividing.
Brian Rupnow said:So---Armed with nothing but blind faith and outrageous courage, I am going to set out to make a 20 tooth and a 36 tooth gear. Remember--No animals will be harmed in this experiment (except maybe me) and the only time wasted will be mine.----Brian
Dan Rowe said:Brian,
Here is a link to a chart for the gear cutter numbers. They state that the cutter is only correct for the lower number of the range. I had always thought it was correct for the middle of the range.
The half number cutters are also listed.
http://www.precisioncuttingtools.co.uk/gearshap.html
Dan
Brian Rupnow said:I'm still not sure what they mean about the #1 cutter when they say "135 to rack" but I'm sure that some helpfull person on this forum will explain that to me.----Brian
mklotz said:That means, I think, that the angle a rack tooth makes with vertical is the pressure angle of the gear.
cfellows said:Brian, the cutter that is used on any given gear (or rack) is not based on the gear it interacts with. Rather, just the gear, or rack you are cutting regardless of what it's interacting with.
Pitch diameter is determined by dividing the number of teeth in the gear by the DP, in your case, 24. So, a gear with 24 teeth has pitch diameter of 1", 36 teeth would have a pitch diameter of 1.5", etc.
To get the overall diameter of your gear blank, you add the reciprocal of your DP X 2. So the reciprocal of 24 is 1/24 which equals 0.0416. Multiply this by 2 = .0832. Add this number to your pitch diameter. So, the OD of a 24 tooth gear would be 1" + .0832 = 1.0832.
Your tooth depth the reciprocal of 24 * 2 + about .006" or so for clearance. This would make the tooth depth .0832 + .006" or maybe round up to .090".
Chuck
