Fuel
spurgear
Active Member
Is it possible to use model Nitro fuel, 10-20 % nitro & 18% oil? Using open intake with adj. fuel flow, or would you throttle air flow also? This fuel (nitro) is cleaner less fume & I can get flavors Bubble Gum, Pineapple, Cherry, etc. & it carries the lube package & my model engine stay clean. no residue like gasoline. Thank you
Just because the fuel has a pleasant smells is not a good idea to breathe the fumes running indoor. Always run outside or at least near the shed door with a fan blowing out.
Try Colemans fuel in place of Gasoline, nice and clean and does not smell very much. Also less harmful than Methanol and nitro.
Thank you Coleman fuel sounds good. gasoline seems to have an extremely high evaporation rate, I cannot remember this happening back tn the 60's, must be the newer dinosaurs.
Thank you
Jasonb
Used Coleman fuel works great & no / or alot less odor.
Thank you
