- Jan 4, 2011
- 1,444
- 406
I find it frustrating when the plans I am following have dimensions which are overly specific. That is, when something is dimensioned 27/64 and then it finally comes down to assembly and I find that it could have been +/- 1/8 and been just fine. I think that what is happening is someone is building a model and designing as they go along and when the model is finished someone else or even the original builder quite a while later measures the finished product and makes the drawing fit the piece exactly. Short of recalculating everything as you are building it it is hard to determine if the dimension is critical. When I see some dimension like 27/64 I assume that the dimension is quite critical or it would have just been labeled 7/16.
Another thing which I find frustrating is when the final dimension can only be arrived at by several mathematical calculations. Also when things like the c/c of holes is critical and the dimensions are given from two different points. ie: c/c is 2" which is critical but is given as 1/2" in from each end of a 3" long piece. I say let dimensioning rules be hanged. Give the builder the dimension he needs without a lot of calculations.
Sorry just a frustrating day I guess.
