- Mar 1, 2010
- 866
- 82
To continue this thread a bit further I had been in touch with the guy who did "Vital Byte" that has a flash steam plant controlled by pic micro controllers that can be found on the Model Boat Mayhem site. I had asked if I could re-post some of his pics here but no reply so you'll have to go over there. However, I did this diagram.
Basically there are two control loops one with an R/C input of speed demand which controls an electric pump pumping water through the flash boiler and the other with which measures steam temp as an input which controls gas flow and hence burner rate. Request for more speed results in more water being pumped, steam temp drops, burner gas flow increases steam temp is maintained and more steam produced, so engine runs faster.
So the only input is speed demand and the rest is controlled by the micro controllers. The guy has a lot of other instrumentation built in as part of his evolutionarily development but he is in the process of rationalizing that down the minimum necessary.
I should say this is not a 'screamer' as shown in the video in the first post but a means of taming this sort of boiler for general use.
These flash boilers have intrigued me and I had my eye on doing one with a figure of 8 of tube as I'd seen an example in the KN Harris book. I also see that fsheslop's boiler was figure of 8. In fact I'd already done the drawing and worked out the surface area when the Vital Byte guy confirmed that my guesstimates matched his design.
And by way of making it real, I've already made the water pump and had it running under PIC micro control
This is all going to happen in very slow time as I have the other boiler to finish first. And a conundrum 'is it a bird, or is it a plane.........?" "Is this a boiler or is it software and programming thread?"
Pete
Pete
