Today brings some very satisfying work. The keyway has been let into the camshaft bush, the small gear for the camshaft drive was machined and fitted to the bush and then screwed together. I started truing up the rear crankcase bearing housing, at over 3" diameter it really does test the drivetrain of my lathe. I can only take small cuts, and the blank is 90mm diameter, to be reduced to 3¼" as a first operation. Perhaps it is time to invest in a new flat drivebelt!
Here's the cam bush in my Drummond shaper with the ¹⁄₁₆" keyway cutter. The cutter is centered on the workpiece using a DTI to find the largest diameter position:
And here's the finished keyway. A slight pickup on the thread, but I only caught it once. There's a small amount of flash in the keyway at the end furthest from the screw thread, I'll grind the key steel a little to clear that:
I made a small fixture to help machine the gear. It's an offcut of hex bar bored to be a tight fit on the gear which is Loctited in while the boss is cut away and the hole bored for the 32tpi thread. Heating the whole with a blowtorch helps the Loctite to let go afterwards:
This is the gear after it's been machined, ready to fit to the cam bushing:
And here's it's fitted to the bushing and the bush end trued to match the gear:
Next was to mount the 4kg steel bar into the lathe to allow me to start machining the crankcase front and rear housings. The bar was held in a four-jaw self-centering chuck and the ends centre-drilled. After that it was time to start cutting down to size, but as I bought a piece of steel long enough to make both the front and rear housings, at some point I'll have to part the two pieces. I'm not looking forward to that, but maybe I'll find a pal with a power hacksaw.
I machined the bar end to fit the cast crankcase, and had to take a picture of the trial fit of the crankcase on the bar end:
A lovely snug fit, now there's just several hours work to do on the bearing housing....
Richard
Richard
