First Engine No Plans.
Remade the piston for two rings and a smaller wrist pin.
Finished piston/rod assembly, but I will replace those weak machine screws for something stronger for final assembly.
Amazing project especialy done without drawings. I can make precisely nothing without a drawing! Look forward to hearing it run, the noise should be good.
Some stuff I do a rough drawing on but nothing like what you are talking about. Things like the crank and cam where it needs to fit I have to draw something out so I know where to stop. Lol
Very good looking parts! What is your displacement between cams on camshaft ?
You are my hero. I am tempted to upgrade and make your engine.
Aluminium pistons
Please advise material specs?
How do you obtain the tight push fit required for the gudgeon pin and piston?
Nice mess-o-parts you have there, now get back to work so we can see it finished! :)
Aluminium pistons
Material? What I have laying around.. Might be a problem but will tackle that when it becomes one.
Piston 6061, cylinder liner is a piece of pipe from hardware store, Rings will be grey iron, crank 12L14, valves and cam drill rod.
For tight push fit pins I use undersize reamers.
So... this is a long time coming. Shelved this project for over a decade.... found it again and started tinkering. Its almost ready to run. Ill update with pics later but here is a quick video. I have a few more shorts showing it and will do a video of final assembly and first fire!
Wow Jasen, what a blast from the past.
I remember seeing your screen name in 2011, and vaguely recall reading this thread.
What a nice engine build.
Glad to see you getting back to it.
Very nice machining work !
Pat J
Very inspiring, that those old projects are "re-visited" and not lost. Keep pushing it.
Just looked thru the whole build thread, looks fantastic. Very nice work. I will watch anxiously to see it running.
With the workmanship displayed I have no doubts it will be a great runner.
