First Engine No Plans.
Well here is another redesign! On the last page I made screw in bronze tappet guides. I didn't have enough room to use them and these where easier to make. I used old cast iron valve guides. cut to size and reamed to 0.2510.
now I need to make a bracket to hold them in.
Now it is time to cut the block and give the guides a place to live.
Here are the last two along with two pics of my little helper (when the machines are off). He is a little too short to hang out eye level with flying metal.
Ready to cut the lobes, I found another way to use my lathes steady rest.
Cutting the lobes was fairly easy. About 15min each of actual machining.
Thanks Gbritnell for this thread -----> http://www.homemodelenginemachinist.com/index.php?topic=5714.0
It made this process almost simple.
I made a few videos of actually cutting the lobes but they are long and slow. Do any of you know a free program I could use to speed parts or all of it up 4 or 5X to post on youtube?
Jasen
Cam lobes just need some cleaning up and they will be ready to go.
Now I could just pin and setscrew this pulley into place but then it would look as cool. And it will be easier to set cam timing if it is adjustable. So I am going to modify the original pulley.
Thanks Robin, seems like forever but getting close now. I just finished the final piston and connecting rod so I have a few new pics to post soon.
