Hi,
I have been trying unsuccessfully for some time to make a double throw crankshaft for a twin cylinder steam engine. Crankshaft diameter is 1/8th. inch. Webs are also 1/8 thick, throw is 1/4". I have tried drilling slightly undersized and pressing the shaft and web together, unsuccessfully because it ended up out of square. Used loctite did not hold, used JB Weld did not hold, tried silver solder, would not flow into joints, tried epoxy also did not work. I do not have the skills to turn the crankshaft as a solid piece, also do not have CNC capability. I have not tried pinning as described earlier in the thread, I guess I would have to pin with 1/16th rod. The other parts of the crankshaft have been made from steel rod on all of the other attempts except one in which I used aluminium for the webs thinking it would press fit easier.
Any other suggestions for working on this project in this scale would be appreciated.
On the happier side I just completed a steam engine with rotary valve -my first attempt to use rotary table on the mill - surprise the engine runs fairly well.
With such a small crank shaft I would try silver soldering. To make space for the solder I would use a triangular file to make 3/4 shallow slots in the holes in the webs.
Regards Tony.
