The Harley Davidson KR engine (45 cubic inch racing engine from 1959 to 1969) was of a side valve configuration with only a 6:1 compression ratio. However, it was very competitive until the overhead valved British motorcycles hit the racing scene, causing the AMA to limit the total displacement of the British bikes.
I raced both a KR and a BSA Lightning 650 on the dirt track in the late 60s early 1970, and I felt the overhead valve higher compression engine (9:1) outperformed the side valve flatheads hands down, even with the 100cc difference.
John W
HARLEY DIRT FLAT TRACK BIKES Fact or fiction???
I know this particular post (#361) is over 6 months old, but I feel like I am dumpster diving in a big industrial park area and finding all sorts of cool and useless/useful stuff.
Is it "bin diving" in the UK?
And speaking of vintage Harley dirt-flat track bikes, I have heard that one of the many reasons the Harleys gave the British bikes such a run for their money is that some of the engine builders shifted the firing timing of one of the cylinders by 360 degrees. That made the
firing sequence change from the standard 45 degree offset (degrees of crank rotation) which was 360 degrees apart minus the 45 offset, were at 0-315- 720-1035 -0 degrees. Those standard firing pulses were spaced apart thusly: zero degrees, then 315 degrees later, then 405 degrees later, and finally 315 degrees later. That also gives the distinctive Harley exhaust sound.
But by shifting the firing of one cylinder by 360 degrees (cam change needed too), the firing sequence became 0-45-720-765-0. That made the firing pulses be almost in pairs instead of evenly spaced almost 360 degrees apart. So the firing pulses were at zero degrees (0), then 45 degrees later, then 675 degrees later, then 45 degrees later.
Supposedly, pairing the firing pulses like that made the power at the rear wheel feel, to the rider, like 2 big pulses spaced almost 720 degrees apart (like a big single) instead of 4 almost evenly space pulses about 360 degrees apart. Some riders found the altered firing sequence and heavy pulses more controllable for breaking the rear tire loose for sliding the tail out thru the turns.
Is there any truth to that or is that just an engineer's overworked imagination? Truth or not, that is an ingenious alteration to change how the power is applied to the track.
Thanks, Lloyd
