engine No12
krv3000
HI all I think I'm showing off gnaw I got Bord waiting for my order of brass to cum so I decided to av a bash at an oscillating engine two days so far sum pics
I made the Base out of a old tin can more pics
soldered it all up made the crank all that's left to do is the fly wheel and piping up
this engine will only be run on air more pics
Well Bob,
If that's what you get up to when you're bored, I can't wait to see what you build when you are keen!
Nice work :bow:
Joe
Hi Bob,
Thats a nice "in between" job! Thanks for sharing that! ;D
Nice Bob. Did that come from plans?
I'm curious about how you made the stand from a tin can. Can you tell me a little more about it?
HI zee sos no plans all of the top of my Head I have seen this type of engine for sale on eBay so I just ruffly coped it the fire box was made by cutting a strip of tin can say 30 mm wide by 65 mm long at both ends I formed two lips that wood be folded together to form the joint then i made a wooden mandrel on the lathe to mack it round and to put back on the lathe to cut the fire box to length left the fire box on the mandrel to drill the holes and to cut out the opening for the spirit lamp this was dun with a dremal the bace is a Peace of tin cut at 31x31 mm sqer then the legs was cut out at 25 mm height then with the aide of magnets soldered it up then with the dremal drest it all up
Very nice indeed - I like stuff made out of odds n ends like that.
HI tel all my engines are made from bits of scrap a part from one bit that's getting mad fore engine No 11 i had to by sum brass plate for the con rod thanks for the comment
Very nice little engine, I have a old Weeden steam engine that is very similar to that design.
IronHorse
