Emco compact 8 help
krv3000
HI all can any of you help my compact 8 is missing its roller tensioner I no I can by a new one buy why by one when you can mack one can any one give me detailed pics and or drawings and dimensions of the roller and dus the roller have oil light Bering in the middle any help wood be gratefully received
Hi krv3000
There is a lathe group " 8x18Lathe ". may be they can help you out.
Hilmar
I have a Taiwan-built C-8 clone and the tensioner roller has 2, 6001Z ball bearings with a snap ring retainer on the shaft to hold it on, no bushing. It is 44 mm outside diameter and is 26.15 mm thick. The 6001z bearing is very common and you can find the OD & ID specs online.
Here's a link to the parts manual in .pdf (in German)
http://www.emcomachinetools.co.uk/P...nualsandSparePartsEmco/tabid/260/Default.aspx
HI dickeybird that's brill thank you for5r your help
