Really, this isn't worth posting but hey, I've got nothing better to do. I spent a few hours in the work shed today working on the cylinder. The shape of the cylinder and the challenge for me to machine it is what attracted me to this build. This cylinder seems to be commonly used in Elmer's designs and a few others.
It's been fun using the RT and my new Grizzly DRO's. It took a good bit of time getting the brass rod to an accurate 1.375 x 1.375 x 1.125" square and then marking lines (double-check of the still-new DRO's) and drilling the ports and holes. Got that all done now, it's time to bore the .75" cylinder next.
So...I'm real proud of myself for figuring out a trick to drilling the angled ports. :idea: I'm sure you old pros have this one in your back pocket but I've never read it anywhere. Or more likely, you have a better way to do it. I know...if you tried it and it works, that's an acceptable practice, as long as you didn't hurt yourself. In the pic above you can see on the plans how the port holes are angled at 10 and 15 degrees where they run from the cylinder edge to the valve plate holes. I used a little math to figure out how deep to drill these holes so they intersect the vertical holes but along the way, I threw out the math and used some trickery.
I placed a wire into the vertical hole and drilled the angled hole until I felt the drill bit wiggle the wire. I knew that was the time to stop drilling. If I went too far I would have drilled into the next vertical hole, ruining the cylinder.
Sandpaper....a wonderful thing.
That's it for today. If I were Metal Butcher, I would have had this thing done weeks ago.
-Trout
