Gerry Sweetland
- Mar 10, 2009
- 67
- 8
Hello,
This is my second build log. I have built 2 of Elmer's engines to completion, Elmer's #2 and #50 and one other that is almost done, Elmer's #37.
I got kind of bored with the Grasshopper, it is about 95% done, just need to do the little fiddly bits like drilling Ø.062" rod with #70 holes and work out the timing. It was taking me a long time and I started getting frustrated so I put it down for a while. It wasn't long before I wanted to try something else so I built the Twin Wobbler. That went pretty quick and I was surprised how it came out.
For some reason I keep looking at the unfinished Grasshopper and say to myself, "not yet... let's do something else". So I started on the 3 Cylinder Radial.
Let me say at first that I owe the guys here a lot of thanks for and appreciation for there skill. I am amazed that most if not all of you do incredible work and are artist in their own right! I use CNC mill and have yet to even come close to what most of you do with your manual machines or just lathes even. Some how I feel like I'm cheating
. I do enjoy taking Elmer's drawings and modeling them in a solid modeling program and figuring out how to set up the model in the CAM software I use and then machine them. The one thing I notice about most of you guy's work is how you really finish off your builds, polishing and painting and adding your own little bits to the original design. So my goal with the twin wobbler was, and this model is, to try and shine things up a bit and maybe do some painting as well as try to be more exact and finished with the final result.
So here goes...
I started working on this model about 2 weeks ago.
Here is what I have so far...
I started with the crankcase. I looked for 1-1/2" hex at my aluminum suppler but they did not have any drops so used a piece of 1-3/4" round. I cut a piece off that was just the right length to fit in my vice and have room to work with down the road. I faced the piece in the lathe after using a DI to make sure it was true. Then center drilled it to help me locate over on the CNC.
Here is a picture after the 1st waterline op. I just skimmed a 1/32" off with the mill.
Here it is after profiling and pocketing.
Then a photo after the spot drill, drill and tapping
Then I took it over to the lathe and parted it off with enough material left to put it back in the mill and proceed to machine the opposite side.
I then placed the crankcase in the mill to machine the holes for the cylinders and spot, drill and tap the holes for the cylinder and steam passage.
So next I started on the cylinders. After looking at some of the other builds of this engine on the forum I really wanted to make them round and put cooling fins on them (a tip of the hat to Stan AKA Sshire, beautiful work). But I also wanted to do something a little different. I wanted to make my cylinders in a rectangle like Elmer's but with a radius on the corners and with cooling fins. But I couldn't figure out to model the fins in my solid modeling software, not around a rectangle any way, I think I know how in a cylinder or square. I'll have to try and figure that out some day. I was gonna use a slitting saw on the mill to cut them. So I just made them as follows...
In the vice ready to machine the first side.
Here is a cylinder done on the first side
I then removed the cylinder and mounted it in my lathe to part off the piece with enough material to machine the opposite side.
I then mounted the cylinder in the vice to machine the other side.
And here is the finished 2nd op.
Here are the finished parts so far. Sorry, I did not take any photos of how I did the base and engine foot
In the next installment I am going to machine the valve housing, crankcase cover and cylinder head.
I'm not sure if anyone would be interested but if you would like me to upload Gcode, drawings, or even SprutCam Project files let me know and I would be glad to do that.
Thanks for reading fellas,
Gerry
So here goes...
Gerry
