carolinamark
- Mar 10, 2012
- 17
- 1
After saving up for a long time, I might myself a Bridgeport clone with a DRO. I've run across something weird going on when I use an edge finder or wiggler.
I have trammed the head of the mill to the vise and it is within .001" in both directions.
I have checked the DRO against the dials and it is working as it should in X and Y axis. i.e. 4.000" dialed off with the dials shows as 4.000" on the DRO.
I am using a 3.000" gage block to perform these checks.
I have used 3 different edge finders(2 with .200 end and 1 with .500 end from Fisher Machine and Brown and Shrap). When I picked up both edges of the 3.000 gage block in the y-axis the DRO shows 3.007 to 3.008 plus the diameter of the edge finder). This happened with all 3 edge finders. When I flip the block and check it in the x-axis it checks within .001" of the nominal 3.000" plus the diameter of the edge finder.
Now for the mystery. When I use a wiggler(chinese import) I get the exactly opposite results......meaning dead nuts in the Y-axis and .007" to .008" off in the x-axis.
The mill is brand new and the DRO was professionally installed. I've checked the scales etc. for loose hardware etc. and found nothing.
Anyone have any ideas?
Any help would be appreciated. Thank you.
