Mike, I think you will have trouble making enough steam in such a small boiler if the wall thickness is 4mm copper, unless you have a lot of heat. I had that problem when I built my "Dickens". I used a fairly heavy walled brass tube for the boiler and it would not raise enough steam with alcohol burner as shown in the plans. I seem to recall LBSC recommending thin wall tubing for small boilers such as these.Hi here is a few pics of my DRIBBLER, the GREEN CABIN is just a prototype cabin will make the original of Copper always do prototypes as copper is scarce and expensive Hoping to finish in a couple of weeks , will use fire lighters and the trays will also be made of Copper,
Many thanks to JOHN for all the help , still need some drawings of the Valves and connection Am using , 4mm Copper tube
Will send more pics later on
many thanks John
MIKE
P/S Any members in Brisbane, AUSI, ?..
The plans for 'Dickens' call for a wall thickness of .035" (i.e. under 1mm) for the boiler shell. The working pressure is only 10 or 15 psi, so this is plenty strong enough. (I hydro tested my boiler to 60 psi anyway). There was no trouble raising enough steam - in fact I often used only one of the two burners to keep the engine speed reasonable when not pulling any cars.Mike, I think you will have trouble making enough steam in such a small boiler if the wall thickness is 4mm copper, unless you have a lot of heat. I had that problem when I built my "Dickens". I used a fairly heavy walled brass tube for the boiler and it would not raise enough steam with alcohol burner as shown in the plans. I seem to recall LBSC recommending thin wall tubing for small boilers such as these.
..Mike, it all looks fantastic! nice work!
The plans for the valves are in what I posted, drawings #900 & #950. (I think...)
TINKER JIM, Hi my boiler is 50 mm dia and , 95 mm long , Copper . will try out the 4mm tube first then change later on, if need be, many thanksThe plans for 'Dickens' call for a wall thickness of .035" (i.e. under 1mm) for the boiler shell. The working pressure is only 10 or 15 psi, so this is plenty strong enough. (I hydro tested my boiler to 60 psi anyway). There was no trouble raising enough steam - in fact I often used only one of the two burners to keep the engine speed reasonable when not pulling any cars.
