Hello,
im still cleaning the machine and its tools, unfortunately the lathe has caused me great sickness. I was cutting out floor to install alluminium floor plate i had to open door and window for smoke to go out, and me geting really sweaty and -2 celsius draft trough the workshop got me the worst cold i had in last few years so im tied to bed currently.
Yes, there is a simple but clever protection from gears spitting the oil on gears, and yes there is balance weights on the spindle. I cant tell you how it cuts since i have still not came to this step. Until now i only run it about every gear combination for 30 minuttes to test gears, it is very, very silent.
At first i would like to glorify my contact in Weiss, mr. Alex Stone for taking care of this lathe. For three days im trying to find casting sand, cast iron swarf, loose bolts, broken bolt heads or anything wrong, but there is none! I even checked the gearboxes but they flushed them and put new oil before delivery so there is nothing bad inside. Furthermore they used such quantities of anticorosive agent even if lathe fell in sea it would not rust. There is really nothing to fix or modify, everything works "out of the box".
In process of shipping and moving in there were 2-3 small ( about 10x10 mm) paint damages which i repainted in minute or two (and that is simple since they use RAL colors i can buy them in any color shop).
However there is some small problems, but nothing about the lathe:
1. They forgot to ship me a 4 jaw invidually centering chuck. It did not fit in machine crate and they forgot to load it in ship separately. However they have apologised and will imeadately send me the chuck by DHL at their cost (ouch that will be expensive...)
2. They forgot to order and ship me a mounting plate for 6 jaw chuck, it will be shipped with DHL immeadately at their cost, and i will need only pay for plate (because they assumed the 6 jaw chuck does not need adapter plate)
The bandsaw is great, it did not work out of the box, but it seems one fuse during shipping broke to pieces and fell apart. I cant blame manufacturer for that, and it was a 1 $ repair. After replacing the fuse, work excellent.
Suprisingly, this is a first machine from China that did not need any spare parts or fixing!
Here is some pictures i make just now, if you want some specific ones, please say so. Cool thing is that dials and leadscrews are metric, but you can flip it over for imperial view (altrough not needed with DRO). I have also checked headstock with bore camera and they really use splined shafts, not keyway like some cheaper manufacturers. All together, they have not lied me any detail!
