I've been absent for several months for many reasons, but have been working in the background. I hit a frustration threshold on the diesel and shifted focus to other stuff, but came back around to this cheap diy dyno set up with data logging that really works.
Here are a few pictures of the actual setup where I was testing an electric sewing machine motor to prove the set-up out.
And it worked!
Some glitches, of course, but it is cheap, the programs work (after much wailing and gnashing of teeth), it records the runs, and it is adaptable to any type of sensors you might have on hand to detect rpm and lever-arm force, or any other type of load sensor or cell.
I just used a wooden friction-type prony brake. The runs only last a few seconds, but could be done however you want. No hydraulics or difficult energy absorbers. The Arduino Nano has plenty of spare computing capacity to automate the loading of the engine, if desired. Also, the setup can be configured to either the load absorber style of dyno shown, or to an inertial dyno if that is the style you prefer.
A very fun project. The sensors and the programming took some work, but zero money. And as always, the possibilities are limitless (almost).
I have a few videos that need some editing but I will post them soon. If you have any questions about this setup, pleas ask.
Lloyd
And it worked!
Lloyd
![CompleteDynoSetUp.jpg CompleteDynoSetUp.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/108/108077-CompleteDynoSetUp.jpg)
![DynoScreenCap.jpg DynoScreenCap.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/108/108078-DynoScreenCap.jpg)
![DynoMonitor.jpg DynoMonitor.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/108/108079-DynoMonitor.jpg)
