JAndrew
- Aug 9, 2013
- 113
- 21
This is my first post here though I've been reading these threads for quite a while. You folks are one talented and helpful group!
Here's something I figured out that I found kind of interesting before I get into my questions. (You experienced guys probably already know this).
I'm cleaning up an Atlas 10H lathe I found locally from a guy who was selling everything and buying a sailboat. The bull gear of this lathe has 60 evenly spaced holes on it's chuck-side face and a small pin you can move in to index a work with these 60 divisions. I didn't know about this feature until I started cleaning up the machine. This opens up a whole bunch of useful purposes from dividing to stamping graduations on thread dials etc.
This got me thinking, "Well what can't I do with 60 index holes?" and "Why 60?"
Here's all the numbers that sixty can be divided evenly by:
1,2,3,4,5,6,10,12,15,20,30 and finally 60.
60 is one powerful number!
If there was 100 divisions instead there would only be 8 possible even divisions but with 60 there are 12 possible!
Why would I ever need to divide by 7 or 9 anyway?
I suppose the globe being divided into 360 lines of longitude and latititude has something to do with the versatility of the number 60.
On to the questions:
How would one use this dividing feature most effectively? Somehow a small milling head must be rigidly attached to the cross-slide, toolpost or carriage. But how is this done best and how was it done on the machine originally?
I've seen one posting here by a smart guy named WheelTapper where he had fabricated a small drill spindle with a pulley and mounted it to this cross-slide. In this setup he had an electric motor hanging from a slide track above the lathe to drive the pulley. Pretty ingenoius. At the bottom of the page on this thread: http://www.homemodelenginemachinist.com/f25/basic-dividing-chester-comet-lathe-9081/
I had considered mounting some kind of spindle directly to the Atlas milling attachment. This gives you the vesatility of being able to adjust the height of the milling bit. My concern with this is that it would not be rigid enough and would chatter like crazy (not the the Atlas lathe is known for rigidity anyway).
Another consideration is if you mount the spindle to the toolpost or milling attachment, you can use your compoundrest angle for things like dividing bevel gears. Again my concern with this is wouldn't it be too loosey-goosey?
Any pictures or advice you guys can offer, I would be extremely grateful. I did a little work on a South Bend lathe with a Dumore Versa-Mil setup when I was in the submarine navy but I still have a lot to learn before I get started.
Thanks in advance!
-J.Andrew
Thanks in advance!
-J.Andrew
