goldstar31
Bearings aside for a moment, i would like to learn to cast Ali, and even brass, though I'm told brass is a pain because it burns off the zinc, so more needs adding. So a little melt pot is on the cards to start some simple Ali castings.
Now bearings, i dont think the bearings are too bad just user error, they do need replacing granted. However they are adjusted to zero play in vertical movement, and nipped up to less than 1thou horizontal movement.
The tool has quite a bit of rake on the top, (makes nice tight swirly swarf). The large dia wasn't dialed in very well, so had anything upto 10-12thou wobble at its furthest most end. When the large (for my myford) 40 dia cut was applied and the tool hit the extra 10thou of wobble it dug in with the top rake and the pulled the soft Ali out the jaws a little (1/2" at most) switched machine off and released the tool, rechucked the Ali and set about cutting just a 20thou dia cut instead.
Unless the ML4 should be capable of taking something like a 40-60thou cut on dia? It was also only chucked in the 3jaw so less holding force as opposed to using the 4jaw.
In your earlier incantation, you were probably one of our Diesel fitters.
The ones in Darlington Market who held up ladies under garments and said 'Diesel fitter':hDe:
There ARE other expressions but ladies might be present:wall:
N
