Fabrickator
Active Member
- Feb 3, 2014
- 32
- 6
If you're dropping a steel cylinder into an aluminum block, you will need at least .004" interference fit. Aluminum expands at 7 times the rate of steel and anything less could become loose when/if the block heats up. You would heat the block slowly to 375* and then drop the cylinder in it.
