Demon V8
OK, Made a jig to hold the rocker arms so they could be machined to the right length and then mill the slot in the end
Good idea so I thought, but not so in practice, they ended up different lengths and the slots didn't come out right either
This is how I set them up, but it didn't work out
  • Like
Reactions: FTX
So this is how I should have done them in the first place, in the 4th Axis from start to finish
Just break them off and touch up the end with a file
Posts for the Roller rockers & the rocker nuts are made
Some more rocker parts
Decided to make the sump a slightly different shape to the plans, more for looks than anything else
I found that there was a mistake in the modelling I did in fusion360, for the first two heads I made.
I redid them in fusion and the cam for the mill
Made two new ones they look better
Got some of the bell housing done, still need to drill the mounting holes
I did the inside and out side on my small CNC lathe, first time turning inside on the cnc
Was a bit rough but you can't see in there when its together, the cuts were a bit to aggressive with the boring bar, good learning curve
extractor plates are made from stainless steel
First drilled the mounting hole then screwed it to a piece of aluminium then did the profile
Carby is done except for the needle
The carby body was machined on the 4th axis from round bar stock, all four side were machined and then all the holes drilled
It was then held in the vice with the bottom facing up and the mounting flange was milled and holes drilled, then it was mounted to a piece of square aluminium and the top was milled
Very nice work there Michael. I made a few sets of heads before getting all the holes correct and not ruining another set! Thank you for all the pictures, that will help when I'm wondering how to set up for some of the parts.
I have some catching up to do once I get back to it. Since winter is here now I'll be doing more basement work and less garage work, so back to the little V8 engine soon.
Rick
Rick
Hi Rick
Its a pain having to make more parts then you need because of mistakes but it is also a good learning process
You tend to think more about the order of operations
Will be good to see some more of your work on Demon
I have been trying to cut the gears on CNC mill required for the V8, never cut gears before
It has been a real learning curve for me, first was to model them in fusion360, then I had to learn how to make a form cutter in fusion360 to use as a gear cutter
Made a few out of aluminium first the had a go at making them is steel, they didn't come out to bad but I might make some more and see if I can improve on them a bit
All Photos - 1 of 1.jpegDemon V8 - 3 of 18.jpegDemon V8 - 8 of 18.jpegDemon V8 - 12 of 18.jpegDemon V8 - 13 of 18.jpegDemon V8 - 18 of 18.jpeg
