and here I was thinking you where turning it into a 16 cylinder LOL
Thanks, Can you advise on the silicon you use? - I have window sealant, bath sealant, engine sealant, and some 3-bond TB1217F product. (Fixed some double glazing, didn't leak in 30 years, but the devil to remove!).
For anyone interested - a link to a tutorial I did some time back on moulding using vacuum and pressure.
Injection / Vacuum Moulding in Polyurethane
When moulding silicone in aluminium moulds be sure you use the correct release agent - I have a mould with a permanently moulded silicone part which I have never been able to recover.
Regards, Ken
Yes it is 2 parts, you can mix it so it sets in 10 to 15 minutesHow long do you need to let the silicone cure before you crack the mold? The product I use needs 10 minutes. It's a 2 part puddy and only comes in light gray.
It is not silicone it is rubber got it off of ebay from a seller Erope it is a 2 part rubber.doc 1955 would you mind sharing a pic of the container for the black silicone you are using ? Any numbers on the can ? Thank you sir.
