Bentwings
Also tryI meant gun drills sorry
also try graingers
Guhring gun drills
And msc
and sterling gun drills
hopefully one of these will ship to you.
byron
also try graingers
Maybe leave some excess stock on all sides of your workpiece so you can re-square it around the hole if drilling wonders off. - zterryHi everyone,
A while back I purchased the Martin Ohrndorf V-12 plans. I've been studying them for a while to get an idea of the construction. I found a supply for 7075 aluminum for the crankcase at a reasonable price. One part has me a bit stumped so I'm trying to wrap my head around the problem before considering starting the project.
The main bore is 42mm through the crankcase which is approximately 8 1/2" long. I've been trying to find a 1.5" drill bit to have a starting point for line boring but usually the bits are way too short on unreasonably priced.
At my disposal I have a Bridgeport and a 13x40 lathe. My first thought was mount the block on the carriage and find the right drill bit and mount that in the spindle. Then leave the setup and install a line boring bar to get to the final dimension.
The crankshaft has aluminum bearing supports, which match the 42mm hole diameter and have press fit bearing. The consistency of the holes seems more critical than the dimensionally accuracy as these parts can be made to suit.
Thank you for any feedback,
Kyle
Graingers likes to price its stuff in the platinum/palladium category in my looking!I meant gun drills sorry
also try graingers
If you look on he internet under blondiehaks you tube there is a good video and explanation of how she did a lone bore on her lathe. By the way she does some excellent work and explains ans mistakes and how she fixed them she is an excellent model machinist and a young lady besides. I worked with a “ roadie the riveter “ type woman in my early years she was all navy flaming red hair and personality to match. Very good machinist. Too. Blonde has a smaller lathe Ethan yours so you might have to work at the extreme limits and make your own boring bar but it can be done.Graingers likes to price its stuff in the platinum/palladium category in my looking!
Great for big outfits that want to single source but not very friendly for little folks!
im sorry I didn’t mean to toss something out that you might not know about.If you look on he internet under blondiehaks you tube there is a good video and explanation of how she did a lone bore on her lathe. By the way she does some excellent work and explains ans mistakes and how she fixed them she is an excellent model machinist and a young lady besides. I worked with a “ roadie the riveter “ type woman in my early years she was all navy flaming red hair and personality to match. Very good machinist. Too. Blonde has a smaller lathe Ethan yours so you might have to work at the extreme limits and make your own boring bar but it can be done.
Byron
By any chance did you look at how the intake and exhaust tubes mount to the heads? The plans basically say to glue them in, which I would want to try for something more elegant.
I think, if I understand your words, that you are making a mistake. you want to hold the block (the thing you are drilling) in a 4-jaw chuck wiht the place where you want the hole centered on the axis of rotation, and hold the drill in the tailstock. That way if the drill wants to wander, the work is rotating so it wanders in a circle which is a close approximation of the hole you want, rather than making a left turn and heading out to the edge of the block. Once you have the starter hole, ream it to exact size and then use that hole as your reference for all other work.Awesome, thank you everyone for the feedback!
I think from what I gather, I'll grab at minimum a 1"x 9 or 12" drill and plan to drill from the headstock with the piece mounted on the carriage. Then line bore to the finished dimensions. Pethertha, I'm glad to hear that I wasn't the only one pondering this issue. A friend of mine does have a taper adapter that would let me put a mt bill into my headstock. I'll see him tomorrow and find out what he has.
Jkimberin, I am in chilly Rhode Island. Hoping the weather will be picking up so I can finally get back out into the garage.
Thanks again everyone
Kyle
just make the drill - it's really easy - get a lengt of tool steel of the diameter you want, grind a D-shaped point and then harden and you are good to goI looked on AliExpress & some of my other offshore haunts for less expensive spade drills. They look to be +/- the same price as N-Am offerings. If I did a lot of this kind of work it might pay to buy an arbor. The replaceable cuttters are reasonable but arbors come in bracketed diameter & reach ranges, so one would have to be choosey because they are spendy. Shop making the arbor is another option if one were so inclined
In my KBC catalog I found several good, conventional drill candidates in the $35 range that could pilot drill the crankcase half way from both ends. I don't think it has to be a pretty hole, just enough to pass a line boring bar through. And even if 2 line boring bars were required (slim & larger/finisher) probably still a cheaper way to go. It looks like the process will require lots of incremental cutter adjustments in any event, so will take some time to get it right.
I cant think of a good way to make a split case in order to hog out the core with end mill & permanently bond the halves together before line boring. There just isn't a lot of sidewall meat for pins & screws & such.
why would you use a ball end mill? that just seems so wrong - a side cutting end mill on a rotary table maybe - can you explain what I'm missing here?I would modify the design to use split bearings, both the half-circles in the block and the half-circles in the bearing caps are milled with a ball-end mill. Every IC engine I've built is done this way, I even modified the DeHavilland Cirrus I'm making to be this way. Remember, plans are only suggestions!!!
my apologies, sorry for the confusion !, I'm not talking about using the end mill as a drill,why would you use a ball end mill? that just seems so wrong - a side cutting end mill on a rotary table maybe - can you explain what I'm missing here?
Let me address that particular question exactly and not infringe on Peters explanation.How is a ball endmill better than a properly sharpened drill bit?
Yes, and they are difficult to get too. I only have a couple and they are always inappropriate sizes for what I needs.Let me address that particular question exactly and not infringe on Peters explanation.
First --let me say that Ball Endmills are made far more accurate than any drill bit.
Just look at the sharpening equipment used to produce the ball , not only correct diameter but a perfect spherical cutting surface. I have seen brand new factory drills with mishaped configurations
Second-- look at a regular endmill and notice they cut on the outside before the center touches metal _ Why.. because the ourside gives stability to the true center location, in other words, the outside of the flutes render guidance
Third-- Drill bits are Longer than endmills, Right ? well that makes them flexible, which means they drift.
Forth-- But you say, I use a center-drill first ...wrong, (!) center-drills are for making center holes for tailstock live/dead centers and are completely inappropriate for starting holes...why ?------
because they do NOT match drill point center angles 60 versus 118 . If you want to match the drill point, use the appropriate "Starting Drill " ( shorty and matched angles) for more accurate drilling
Fifth-- Starting with a ball mill (no predrilling) means the ball mill is not affected immediately when it touches the surface , which means metal variations/inclusions have no affect and the very face of the ball mill is like a facing operation before the plunge , this means the mass and rigidity of the ball cutter is used to get perfect centering on the workpiece and the amazing thing is as it penetrates the metal , the sides further up the ball , nearer the OD, actually can shift the cutting center to match the true center of the ball endmill.
Sixth-- Ever wonder why drills come in 118 and 135 angles ? it has to do with cutting load and materials , and the 135 is more rigid and which is closer to the ball endmills construction
Hope this helps you and others understand the value of ball endmills
I spent over ten years running a gundrilling operation , drilling up to 48 " deep on stationary 4140 dies which is more difficult than using a gundrill lathe for getting accuracy and we did all kinds of tests and evaluations, and by far , the most accurate and concentric holes were ( started) achieved with Ball endmills, and which sometimes even required the cutters be custom ground .
YOU want an accurate hole ? use a Ball endmill and go to one times diameter in depth
Don't have the size you want , use the next smaller ball endmill and make the hole and then use your drill to size, as the drill will not use it's point and be guided by the existing hole and when it reaches the depth you have and want to go farther, the drill will use it's flutes for guidance, not the ground tip
Rich
Ric
I'm also a fan of using endmills for such purposes, if it works it works. Standard endmills also make great little boring bars to square up or center holes too small to get a proper boring bar in.Let me address that particular question exactly and not infringe on Peters explanation.
Rich
