Another thing that helped me conceptualize what I was trying to do in 3D modeling is to think of the old Play-Doh extruder.
The 2D sketch that you create on a sketch plane is the hole in the extruder die, and the extrusion in 3D mode is what is pushed or pulled through the die.
So the technique is to get onto an appropriately placed sketch plane, draw a shape, toggle back into 3D mode, and either extrude, cut or otherwise manipulate that sketch into a 3D solid.
Jumping back and forth from 2D sketch mode to 3D mode was extremely confusing, but you can't do anything without understanding how that works.
You begin with three basic planes, which I think are top, right and front ? I don't even pay attention to the actual plane names these days.
You can insert new planes anywhere, and at any angle, as needed, and learning that was a bit of an art too.
You can extrude solids, or extrude cuts.
Another way to think about it is to slice an orange.
The shape that you see in section is a circle, so to create a 3D sphere, you draw 1/2 of a circle, and rotate it around an axis to create a sphere.
The secret to learning 3D is to be able to conceptualize how to slice up a solid part into pieces, and then create the 2D sketches to make those solid parts.
