Curved and Classic "S" spoke Flywheel construction
Cedge
Warning.... this will be a long post with heavy photo content. Strong Coffee and heavy Donut supplies should be laid in before attempting to read it all in one go.
When I began the Water Pressure Engine Project, the idea of using curved spoked flywheels quickly floated to the top of the "I want" list. Powderkeg was gracious enough to offer me a pair of his cast flywheels, but his work circumstances and some serious health issues made it impractical for him to do so. I still thank him for his generous offer, but I also told him to concentrate on the important real life issues and forget about the castings.
Bogstandard came to my rescue by sharing an article written by the legendary Philip Duclos. The article shared the secrets of manually machining curved spoke flywheels. At first glance, the instructions were a little intimidating but after a little study, a couple of things became clear. Philip Duclos was a genius with a flair for making potentially difficult things easy to understand. As I progressed, I also learned that he had boiled the process down to its most essential form. No wasted steps and no wasted advice... he gave it all to you in as few words as were required to get the job done.
Once I was relatively sure of the process Duclos described, I decided to give it a go. The first step was to come up with blanks of the right size for the engine. After some testing, the engine looked best with 4 1/2 inch diameter wheels. Since I only had 3 1/2 and 4 inch brass and no cast iron, I decided to build the blanks by pressing the brass inside aluminum rims. This lead to choosing a 3 piece design where the inner hub would be aluminum, the spokes brass and the outer rim in aluminum.
Flywheel blanks after press fitting and surfacing for mill cutting
The center holes were reamed to 3/16 so that I could use a 3/16 dowel pin for centering purposes as well as for adding stability to the set up when the blanks were placed on the rotary indexer. Since I didn't have a rotary table until a couple of weeks after this project was completed, my handy dandy home made manual indexer was Hobson's choice for the project.
You'll notice the blank is placed atop a piece of 3/8 aluminum plate. This plate will become a very important milling ji,g as we go along. It too was reamed for the 3/16 dowel pin and was visually squared and a witness mark was made on the indexer for quick positioning when required.
Blank mounted on the indexer in preparation for creating the milling jig
The process began with locating the required holes which would serve as the corners of the openings between spokes. For a 5 spoked wheel, the wholes are located at 72° intervals, 5 at the hub and 5 at the outer rim. These were first center drilled and the placement from the hub was noted for double checking when drilling the actual holes.
The blank with 5 of the first 10 locations being center drilled.
The larger holes form the corners of the opening at the hub while they form only one corner of the outer rim. The typical straight spoked flywheel would have the same size holes on either side of the spoke, but not when doing curved spokes. The opposing side will require a much smaller hole to allow for the curves.
The large diameter (7/16 in.) corner holes drilled to size
Here you can see the complete set of holes. The smaller holes allow for a tighter corner radius than the larger corner holes. This gives a nice graceful blending of both sides of the spokes into the rim of the flywheel.
All the required holes have been located and drilled prior to cutting the openings
The first 4 holes drilled were specified by Duclos so that they could be used to form a milling jig. The first 2 inner holes and the first 2 other holes were drilled into the sub-plate beneath the flywheel blank. This jig is used to position the flywheel and to prevent movement of the work piece as the heavy milling is done. They also served as reference points for sizing and locating the pivot points for the cutting arcs.
The milling jig with the corner holes in their proper places
The curvature of the spokes can be varied, although Mr. Duclos made no mention of this fact. I discovered this while tinkering with pencil drawings that I used to wrap my head around the project. Since Duclos suggested that different sized flywheels would require reducing or increasing his dimensions, the pencil drawings were an excellent aid and helped me see how the curves and holes related. This exercise let me go for a different curvature than his instructions showed.
The alteration is done by varying the diameter of the 2 radii of the second small template that had to be made. The template tool is made with 2 different radii, allowing one template to be used to lay out the arcs for both sides of the spokes.
The second template being used to locate the "inside arc " pivot points on the milling jig
In the above photo, the dowel pins are in two holes of the same size. This allows the center point to fall on the centerline between them. The drill bit is used to mark the location so that a 3/16 in hole can be reamed to accept the 3/16 dowel pin that will be used as the pivot point for the inside cut.
The photo below shows the second pivot point being located. The 3rd large hole is from of the adjacent cut out, since it is located on the opposing side of the spoke. It will have a larger radius, but the use of the 7/16 inch dowel pin and the smaller 1/4 inch pin throws the pivot off the centerline and creates an offset that will effectively control the amount of taper the spokes will have. As mentioned previously, varying these two arcs will let you vary the visual style and taper. The 2 new 3/16 holes will become placed over the indexer's center pin so that any rotation is centered on the arcs of the spokes.
The second template being used to locate the offset of the "outside arc" pivot points on the milling jig
Here's where the sweating began...and Brian, I definitely know the feeling well. The small 1/4 inch dowel was used as an anchor while cutting the inside arcs of the spokes. The large holes took some of the stress out of the operation by providing an "escape" point that didn't require intense attention to the DRO. The cuts were made to the final dimensions which is something I would do differently on the next project. Leaving about 1/64 of material would have made final clean up much, much easier. The cutter was a 3/16 inch 4 flute which made multiple cuts to prevent breakage or heavy deflection.
The inner arcs are cut... note the work piece offset and dowel pin used for indexing the flywheel
Here you can see the "outer" curves being cut. Once these cuts were completed, the spokes were visible for the first time. It was still hard to see the final shape but the curves were now there and things were getting a lot less stressful. A word to the wise... when the stress comes off too early, look out... the gods are just about to have a belly laugh at your expense.
The outer arcs being cut... again...note the work piece offset and dowel pin used for indexing the flywheel
The next series of cuts got me into trouble. Milling the slots along the outer rim took place after the "stress relief" had occurred. Like I said... look out!! The rhythm of repeating cuts set in and when I got momentarily distracted, I dropped the quill down and began a cut from the wrong end of the slot that I was cutting. This resulted in the end mill doing some serious climb cutting, which wasn't noticeable until it exited the slot. When it escaped into the "safety" of the large drill hole, it never slowed down.
The results of that brie moment of inattention was a cutter sitting halfway through the previously freed spoke right along the outer rim. No.. I didn't throw the part, but the air was distinctly blue for a few minutes. What had seconds ago been a perfectly curved spoke now had a huge chunk missing and hiding it from view was not an option. At times like this, I've learned to just stop and walk away for a bit. When i returned, I sat down and began to study the damage. Then i picked up a file and began picking at the damage to see what could be done. In a matter of minutes the situation went from a bummer to excitement. There in front of me was a perfect example of the classic Cretors style S spoke.
If you look closely, you can see where the "mistake" is being added to each spoke
After the panic and excitement of finding such an easy and attractive solution. the rest of the project was almost anticlimactic. The spokes were cut and the S spokes were uniform, so the rest of the action was doing clean up. As I mentioned earlier... I made the foolish mistake of going for finish depths when making the cuts. Now the tool marks had to be hand filed due to the thin rim my design. I continued the hand flining and added rounded edges to the spokes. The rest... as they say was history.
Steve
Steve,
Many thanks for documenting with photos a really impressive bit of machining. The end product is beautiful. Walking away from what seems a ruined piece of work has saved me from tossing many an otherwise salvageable part. Your save turned out to add interest to the work! :bow:
Phil
:mad: Sadly, your Donut warning came around 4 minutes after the local store shut :wall: ............... however coffee is always on hand so I tackled the post only 75% armed ......... (we do have choccy biccy's in stock) ............ ;D
Firstly, many thanks for taking the time and trouble to photograph and document this, clearly you enjoyed it, as have we ........... but nevertheless .......... Ta 8)
OK I've read this about 3 times and it's beginning to sink in, Mr Duclos was certainly a very clever lad, and you've taken after him dam well Steve ........... top class work mate ........... and top class post :bow:
Now where do I get a copy of Mr Duclos's articles .................. :(
CC
Phil
Thank you for the kind words. Like everyone else, I'm still learning every time I turn on the machines. One of the most important lessons has been to relax and take it as it happens. Salvaging that mistake was one very happy turn of events.
CC...
I recently purchased "The Shop Wisdom of Philip Duclos" on amazon.com. It's a beautiful hard bound book full of tips and projects Duclos submitted to HSM magazine over the years. I've also learned there are a whole series of "Shop Wisdom" books that I hope to acquire over time.
Thank you too for the kind words. I'm just beginning to work at a level I'd only hoped to one day reach. I still have room to improve and such encouragement makes it worthwhile to keep trying to get these black arts within my reach.
Steve, that's one thing that keeps this hobby interesting! No matter how much you learn and how proficient you get, there is something just around the corner to throw you for a loop and keep the old noodle engaged!
Great write up there on your save. Your work on the flywheels (okay, the rest of the engine, too :p) is magnificent. This is great proof that sometimes the mistakes are diamonds in the rough!
WE...
My noodle is even engaged in loops when there is no corner...LOL . If I had to give anyone advice, I'd simply pass on the same advice I've adopted from one member's old tag line. "Make one perfect part at a time." The definition of perfection is a personal thing that each operator has to define for himself. If each part meets your personal definition of perfection, the finished product almost certainly has to be perfect, by the same definition.
I enjoy keeping a project challenging, so I sometimes make things more difficult than they probably need to be. It's an attitude that would more than likely drive some to binge drinking. It's simply my way, but it works for me.
Steve
Steve nothing wrong with that! :bow:
My approach is simple as well... I try to make the current part better than the last one. Ya know, better tolerances, better surface finishes, more efficient set ups, etc. That may sound a little goofy, but I really do strive to improve each time I touch a machine. As you say, it works for me!
I keep saying this but one day I'm gonna try this flywheel lark!!!
I look at you engine Steve and the flywheels just pop out, you have a real masterpiece there and A slight error has made it all the more eye catching... You could have kept quiet and everyone would have called you master, instead of ol' lucky!!! :big: ;)
I am also happy that you documented this.... I will make a spoked flywheel,I will make a spoked flywheel,I will make a spoked flywheel,I will make a spoked flywheel........
Ralph.
Very nice write up, Steve. I'm going to have to try this.
I'm still having trouble visualizing the path of the tool and work movement, but I guess it'll make sense when I make a few practice pieces.
Thanks for posting how you did it.
That is a fantastic write-up, you should make a PDF of it and put it in the downloads section.
Hopefully one day I will get to try this myself.
Thank you for taking the time to document this for us all to learn from / copy.
Tim
Many thanks Steve ........ 8)
I have now spoken at length with the chief financial officer and ........... it is apparently OK for me to order and pay for a copy, which will then be spirited away upon arrival and then presented to me on 25th December .......... wrapped in brightly coloured paper .............. whilst I'm looking forward to receiving the book ........... I somehow think I've been diddled ??? .......... :D ;D ::)
;) CC
I like that rotary table. How was it made? Inquisitive minds want to know these things. ;D
BTW, nice write up. I had lots of coffee but no donuts. :'( :p
Bernd
CC
Take a page from my youngest grandson... stash away your own roll of paper and tape. The little rapscallion played with his Christmas present for several days before his grandmother spotted the badly wrapped fake....LOL. Not too shabby thinking for a 4 year old kid...eh?
Bernd
Back before I was making much of anything I wanted to keep, I made lots of tools to learn how to run my machines. One project required a pattern of holes and i was at a loss to get them right. Even knowing how to use a compass, my lay outs were still off the mark by a bit.
I spotted a small indexing plate offered by http://www.cartertools.com . It was $60.00 bucks but I saw where I could make it fit my mini lathe, so I bought it . Once I had the indexing capability on my lathe, I "copied" the plate over onto the edge of the aluminum round that I used to build the indexing table. The rest was just keeping things concentric and in tolerance and figuring out how to lock it all down.
The indexing plate and the edge of the table both have rows of holes numbering 60, 50 and 40. These combinations provide the largest number of possible hole patterns in the fewest required holes.
If I can round up all the photos, perhaps I can do a post on that build too.
Steve
For all you really old farts duffers like me who have dabbled in this hobby for a while...
If you have back issues of PIM ("Projects in Metal" - the forerunner of "Machinist's Workshop"), the Duclos article on constructing curved spoke flywheels (the article from which the book entry Steve refers to was taken) is on page 4 in the April 1988 issue.
Steve,
Adding my thanks to all the others for your efforts in documenting the curved spokes method :bow:
I still don't understand it but as ksouers said it should make more sense after a couple of chip and scrap machining exercises.
Best Regards
Pure magic. Having just sweat my way thru my very first straight spoked flywheels, I can truly appreciate what you have done.---Brian
Great job with that. I would have taken a different route though since I have access to a different machine.
I would have made them using my bridgeport mill retrofit with a ProtoTrak SMX controller. dumped in a cad file and let thing run. ;D
But again, nice job on figuring out how to do it without that technology...which in machining is part of the fun.
Those are really nice fly wheels and a good write up.
I did some train wheels in the past with the help of modern technology too.
I can really appreciate the time and effort of doing things the old way!
mite
I'd like to read more about your homemade indexer. Looks like a clever idea. How did you work out the selection of 60, 50, 40, as "best" for numbers of holes?
P.S. Those flywheels are beautiful!
