So ive been doing some research and come up a tad short. Im designing a 5 cylinder engine but dont know how big to make the counter sinks or how much to offset from the mains to get a stroke?
Like is there an equation that include the primary and secondary vibrations to establish the offset distance and overall diameter of the crank? How do you guys figure out how much stroke you want?
I tried to use a crank from grabcad and scaled down to my ideal size but the mains and journals are way too big even when scaled down. So in trying to get my own going.
Also ive seen some builds where the crank is built up or machined in one piece using fancy rigs. But i havent seen one using a 4 jaw on a lathe, why arent adjustable 4 jaw chucks on a lathe used? Too much slack? None availvle for your lathes? Easier using an eccentric turning rig?
And how about centerdrilling on the horizontal axis where the individual rod journals would be at. For example 5 holes around the main journal or center of the stock at 60 degree increments. And then just mount on a live center and turn?
Ok so the related tgreads at the bottom of the page shed some light on the crank maching. But still feel free to share your experiences.
