digiex-chris
- Dec 6, 2010
- 263
- 58
I'm trying my hand at refurbishing a glow RC airplane engine. There's a fair sized scratch that seems to be letting out too much compression when the thing is warmed up and expanded to running size. It's an aluminum piston, with a nickel plated brass liner, non-ringed. It appears I'm going to have to go almost completely through the nickel plating to remove the scratch, so I expect it won't last too long after I do it, but I'm doing it more of a proof of skills before I go on to building my own engine. Maybe I'll even make a cast liner for this guy later. This guy is definitely not worth the trouble, I can buy a whole new engine for $65, but when has that ever stopped us from spending more money and way more time to fix it ourselves?
Anyway, how much of a reduction in life should I expect with the brass exposed? If I can get a gallon of fuel out of it I'll be ecstatic, but I wouldn't mind a benchmark to other people's experiences with brass cylinders. I'll be making a new piston of course. Any gotchas I should be aware of?
Second question, the more important one, is the making of the lap. I measured the cylinder with bore gauges, and found a taper of about 0.001" over the 1.5" length of the cylinder. I even went as far as chucking up the cylinder, and sweeping with a DTI to match my compound to the angle. Then I cut a taper on a piece of aluminum that barely fit into the bore. But when I added lapping compound, I couldn't fit it anymore! So I cleaned it off, and took another 0.001" pass off. Now I can fit the lap in the cylinder, but the taper is so long to get me to the size I need, that I can't cut that length with my compound.
There's gotta be a better way.
This must be why people make expanding laps. I was thinking of trying my hand at a barrel lap. Is there an easier design? How do you determine the starting un-expanded size of the lap to account for the lapping compound? it's a tapered bore. I'm planning on lapping it without pulling the lap all the way through, leaving the most expanded part at the bottom of the cylinder to get the taper. Is this the right idea?
And the piston: with the tapered cylinder, do you use a cylindrical piston? This original seems to be. Is there an improvement making it tapered to match the bore?
