MrMetric
Rich is right on the target. I've done both. In fact, even though I have a Phase Perfect, I elected to rewire my Hurco CNC because the *only* think on it that was 3 phase was the spindle motor, which was driven by a VFD. Ironically, that particular unit itself was run on single phase. I ended up having to replace that VFD, but I kept the concept and simply reworked the inputs to the mill, thereby ensuring everything was on single phase.
The PP is a nice solution, but *very* expensive. My replacement CNC to the Hurco is a true 3 phase machine, though, so I'm glad I have the PP. The new CNC uses a Mitsubishi control which has amplifiers that require 3 phase. Sure, internally I'm sure it still makes a HV DC bus, but they put phase detection logic in it. And, you have to use their amps because there is a proprietary interface between the control and the amps. Not an easy thing to get around unless you want to do a whole conversion.
I think Rich's comments are accurate though. There is a lot of "well, in this scenario then.... but in that scenario, things are a little different..."
