I used collects and end mill holders
They both work great.
The end mill will crepe around with both types.
When first started using Bridge Port mills I used collects. I found both holders work the same.
The ER collects have good adds.
You buy collects for morse tapper 2-4 and R8 there are other types but less command.
Today I just use end mill holders fast to change.
If you having end mill creep use the next smaller end mill then finish with size you need.
I was wondering if there is a reason for using ER collets with end mills? Does it reduces runout because it has more contact points?
