dnalot
Project of the Month Winner !!!
UC100 Motion Controller
Well it happened. My old PC with a parallel port lost its magic smoke and died. I was expecting that to happen so I had backed up my Mach 3 program a while back so I wouldn't lose the setup for my CNC router table.
Not wanting to spend a lot of money I opted to try the UC100 parallel port adapter (motion controller) for a USB port. I have been saving an old PC-64 bit with Win 7 installed for this purpose. I bought the UC100 from Amazon and found the software to install it here http://www.cncdrive.com/UC100.html
The UC100 should work on all windows versions from 7 thru 10.
To set things up correctly you must install Mach 3 on the new computer and then copy the original Mach 3 directory from your old PC over the Mach 3 directory on the new computer. That will transfer your license and setup files. The License must be valid. Only then can you install the UC100. Load the UC100 Installer and a popup screen will let you load the drivers and the plugin for Mach 3. The first time you load Mach 3 a popup screen will prompt you to select the port, select the UC100 port. Your now good to go. Actually if your old PC is as old as mine was you will probably need a new keyboard and may need to setup your hotkeys. And you may need a gender adaptor for a parallel port. Total cost was $135
Mark T
Mark T
