Chucks Single--Conventional Valving
SandyC--You may very well be right. I simply don't have enough background in steam engines to agree or disagree with what you are saying. I do know that I have built a beam engine, (The one featured in this months "Home Shop Machinist") and a twin cylinder horizontal engine, and they both have the eccentric set up to have exactly half the offset on the eccentric that there is on the crankshaft.---And they both run very well!! When I set out to make this modification to my "Chucks Horizontal" I was uncertain of how to approach it, so I modelled a similar engine with a similar valve arrangement from plans originally done by Rudy Kahoupt. I know that one works well, because a friend of mine built the engine from Rudys plans. My 3D software allows me to assemble the engine, then rotate it slowly and study the valve mechanism at all degrees of rotation on my computer. I know that "It works on the computer" are famous last words, but the proof of the pudding is in the eating, as my mother used to say. I'll have this modification finished next week, and then I'll see if it works. One thing about it---If it doesn't work, I will certainly post that on this thread. I am not afraid to post my failures as well as my successes.---Brian
Brian,
Just to give you a feel for what Sandy is saying.
In a full sized engine with a stroke of around 50" and a boiler pressure of 180psig, the valve travel would be around 7"
A ratio of ~1:7
In some triple expansion engines the valve travel can vary between cylinders eg 48" stroke; HP valve travel 6 1/2," IP 7," and LP 8"
Think about the additional rotating mass balancing problems if the valve travel was half the stroke and the engine at say 150 rpm.
Hope this helps.
Best Regards
:) :) ;D ;D
Hi Guys,
Ain't valve gear fun :big: :big: :big: :big: :-\ :-\ ;D ;D ;D
Brian,
Don’t get me wrong my friend; I am not saying your design will not work.
In fact I expect it to work just fine, just like all your other engines, since the valve over travel is, in this case, not going to present any major issues.
What I was trying to establish was how you came up with the eccentric offset and your explanation provided the answer. No problem on that score and in this particular case it should not give you any issues.
Ok, having established your method, what I am now trying to convey to you (and any others who may be following this thread) is that the required valve travel, and hence the eccentric throw are not directly related to the crank throw but to the required cylinder port width, which in turn is related to piston speed, piston area and steam velocity.
Piston speed is directly related to rpm and the engine stroke, so in this instance crank throw is important… but not in the way you are relating it.
Lets take a couple of examples: -
1st lets take an engine with 1” bore and 1” stroke rotating at 500 RPM
2nd Lets compare this to an engine of 1” bore but having a 5” stroke rotating at 100rpm.
If you use the formulae I gave you in my last post, and using 4000 for the steam velocity, you will see that in both these cases the required port cross section area is identical at 0.01635 sq ins.
edit: in the previous posted formulae I neglected to state that the resulting cross sectional area (a) is in sq.inches. Original post edited to add this fact. end edit.
The piston speed is also the same in both cases (83.333ft/min) but the strokes are not; with the second example being 5 times greater.
In both cases the required port cross section can be obtained by drilling a hole of 3.7mm dia (0.145”), this being the nearest generally available drill size (actually a number 27 drill).
The required piston valve would need to have a land the same as the port width (0.145”) and the total travel required would be twice this value (0.290”) in order to open the port fully to both steam and exhaust.
From this it is clear that the eccentric throw is only required to be the same as the port width at 0.145”.
Clearly the same valve and eccentric dimensions can be applied to either of the example engines and both would work to the design specifications.
Ok, lets compare this to the values you would get using your method for these 2 examples: -
In example 1 the stroke is 1” so the crank throw is 0.5”.
If you now deduct half of this we arrive at 0.25”.
If we also deduct the port width (0.145”) we arrive at 0.105”; which is smaller than the port width.
You then go on to further deduct ½ the port width (0.0725”); which results in 0.0325” for the eccentric offset.
The result would be an eccentric having a total throw of only 0.065”.
Clearly this is not correct since it results in an eccentric with far to small a throw.
In the second example we have a stroke of 5” so the crank throw is 2.5”
Deducting ½ of this we arrive at 1.25”.
If we now deduct the same 1½ x port width from this (0.145" x 1.5 = 0.2175”) we arrive at an eccentric offset of 1.0325”, which will result in a total throw of 2.065”
Again this is clearly not correct since we now have an eccentric with an extremely large throw.
Ok Brian, please do not think for one minute that I am picking holes in your design… nothing could be further from the truth.
What I am trying to do is help you to understand the theory a little better, I hope it will be seen as such.
This whole issue becomes far more important when you come to designing double acting engines where the valve travel must be constrained to quite tight tolerances…or very strange things, or even damage, can occur.
To this end, I trust the above will go some way to your understanding and help you to design your engines more easily.
Best possible regards.
Sandy. ;D ;D ;) ;)
Today I made the intake pipe and soldered it to the valve body. I also completed the eccentric cam and slid it onto the crankshaft. (By the way, that cranshaft isn't as badly chewed up as the picture makes it look.) Hopefully I will get the eccentric strap made up this weekend so I can try this engine out.--It wil do quite nicely with one flywheel on the far side from the cam for try-out.
Well---This is it!!! Perhaps my valving design is a bit "wonky" according to sandyC, but ya can't argue with success. (Sandy--I will try and incorporate your design into my next modification.)
Sandy, thank you for that excellent information. I've saved it as a text file for future use. ;D
Of the 5 steam engines I have built, this design is probably one of the simplest and best runners of the lot.--Especially when made with this relatively simple valve set-up and cylinder head instead of the "hit and miss" version. If anyone admires these engines and is looking for a "first engine" to build, I highly recomend downloading my plans from the download section of the forum and using this cylinder head/valve arrangement to get their feet wet. If you want to try building the governor and the "Chuck Fellows patented Pop Pop cylinder head/valve arrangement", it can always be added at a later date. This is a great little engine, in either guise.---Brian
