Kegan
Thank you for the discussion. Very informative
Followed up on the reference to "zink pest" in you post. Interesting. I saw plenty of examples in automotive parts like door handles and mount brackets in the '40s and '50s in my dad's garage. That's apparently where zink die castings got their bad name.P.S. Thanks for all the useful information above gents, I enjoyed your posts above.
Just to beThe Zamak 27 is very strong stuff.
Just to bepedantica pain in the posteriorprecise: ZA 27 is not called Zamak, because it does not have the magnesium. Or at least, that is what I think I understood from reading some of the interesting links above ...
It seems like at some point they transition from calling it "Zamak" to calling it a "zinc aluminum alloy".
Its all good for me.I failed to put a smiley face on my post - I was intending it to be humorous (as indicated by the strike-outs) - I hope it came across that way!
If I recall correctly Dinky Car Toys were made from the same or very similar material.Followed up on the reference to "zink pest" in you post. Interesting. I saw plenty of examples in automotive parts like door handles and mount brackets in the '40s and '50s in my dad's garage. That's apparently where zink die castings got their bad name.
All metals oxidize and what do you do is to coat them with oil. The parts of a lathe or mill should be coated that are steel or cast iron I coat since they sit in my garage.Don't know how to stop the rot.. I think Myford lathes has some Zamac parts on them also...
