I have a need to case harden the rocker arms of the Kiwi and I am seeking advice on the "best" process.
I have a good supply of propane but I do not have a furnace - just fire bricks. The parts are about 35mm x 7mm x 7mm and machined from bright "mild steel" bar. I don't have the steel ident.
I have looked on Youtube and the advice ranges from furnaces with temperature equipment to dipping the parts into Kasnet - which I have but am concerned about its safety.
What is the easiest and simplest method of case hardening very small parts
Many thanks in advance
Mike
Mike
