Luc--Did you get your lathe fixed? My BusyBee 2227L lathe has given me great service, but it must be smaller than yours, as its only 110 volt. About 2 weeks after I bought it 5 years ago the starter switch burned out, but they sent me a new one when I called and that's the only trouble I've had, electrically.----Brian
Hi Brian
they receive my new motor yesterday, they called me to go and pick it up
and I ask them to check it before cause I was going to have a "fit"
they called me back 1 hr later saying " don't worry Luc we wired it checked
it and everything is fine";D
Drove down there and because of so many problem with these motors, I told the technician show me that its fine be fore I leave.
dam it didn't reverse th_wtf1th_wtf1 is going on here.
took his multimeter and start doing some testing, needless to say I was steaming.:fan: after a few minutes of testing we realize that the wire ID
were not on the proper wire...... the motor was running on the starter cap and circuit all the time. When I got home check my old one and it's wired the same. The wiring diagram plate is wrong.
I should be installing it today after storing my 3 motorcycle for winter
and hope its the end of this story.:wall: I told the store manager if I have one more issue with this lathe I'm just going to bring it back and get another one
cheers
Luc
