On to the bearing caps for the crankcase. Started with a piece of rectangular brass bar, milled it down to dimensions with it left long enough to get the four caps out. Then, set it up in the vise with the top edge sticking out and milled out the flats on either end of the caps.
![IMG_5667.JPG IMG_5667.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30432-452bd8bb7e812a7c002eaea9ca832359.jpg)
Switched over to the drill chuck, and drilled out the mount holes (2-56 tap size). These will get opened up to 2-56 clearance later, for now they will act as drill guides for the holes in the case. I stamped each one with a number to match the posts on the crankcase, in case there were any differences cap to cap, and sawed them apart. No need to mill the ends square, that will be done after they are in place.
![IMG_5668.JPG IMG_5668.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30433-2bc8c8139100f6c140c6a7698442a12c.jpg)
Then marked centerlines on the crankcase, and one by one clamped them in place and used them as drill guides to drill the holes in the posts. After that, tapped each hole to 2-56.
![IMG_5670.JPG IMG_5670.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30434-414aea7ea0c67115e8be8206c08ec465.jpg)
With all the holes tapped, it was time to go back and open up the holes in the caps to the clearance size.
![IMG_5671.JPG IMG_5671.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30435-1b05f1066d94d9acf6265e5908122629.jpg)
Last operation was to bolt all the caps in place, nice and tight, and with the crankcase bolted to the mill table again it was time to take all the caps/posts down to final dimensions. Got it squared up on the table, and first milled off the ends of the caps even with the edges of the posts. Then, took a light cut on the end of the case - that surface acts as a measuring point to all the rest of the sides. After zeroing the handwheel at that setting, cranked out to each of the other posts and did the corresponding side. The posts were all left about a millimeter thicker than needed, to allow for any variance during soldering them up. Again, this is Kozo's method, I did not think this up myself - worked like a charm.
![IMG_5674.JPG IMG_5674.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30436-c3f7fbb39eb1ca069205232687f9cb4b.jpg)
With the right sides of the posts all done, I went back and took the left side of the first post down to thickness, and used that point as the start to crank over to each of the others.
![IMG_5675.JPG IMG_5675.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30437-ab2c78831ad1bbbc1b939b5cc238352a.jpg)
Next photo shows the crankcase sitting under the engine to show current state - one thing that I am going to do beyond what Kozo shows is to mill in a small flange around all the lower openings. I saw that flange on the real trains down at Cass WV, and I think that little detail will look good on the model too. Will do that after the rest of the machining on the crankcase.
![IMG_5676.JPG IMG_5676.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30438-623e1249d34f6ec4259ed42009d7bf61.jpg)
The next step is a biggie - drilling for the main bearings for the crankshaft. The last photo shows how I am setting this up, on the mill with the crankcase bolted to the tilt table (drilled/tapped an extra set of holes in the table to match the holes in the crankcase).
![IMG_5677.JPG IMG_5677.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30439-0f453a1f3d498751c3fa67b7176cadc9.jpg)
The mill column is JUST tall enough for the drill to fit - glad I went for the taller column a couple years ago. Kozo did this operation on the lathe with an angle bracket to hold the case - my Sherline is just not big enough to do it that way, so I will use the mill. Going to have to make an extension for the center drill, and spend some time to ensure everything is squared up properly. That will be tomorrow probably - want to start fresh in the morning, one goof and the case is scrap.
