On to the main attraction: Act 1: The Cylinders
Last time I got the blocks for the cylinders shaped down to outside dimensions. Time for the 'boring' part. First up was to chuck the block up in the 4-jaw again, but this time offset towards one corner. The bore is offset to leave room for the steam passages and bolt holes. Since the number one cylinder block is facing the other way from the number 2/3 blocks, all of these operations took some careful checking to make sure I was orienting the blocks correctly (good time to be paranoid - Murphy is always out to get you!). Anyway, using the dial indicator each time, I offset the blocks the same amount in both directions (0.052", as I recall), and then drilled a starter hole for the boring bar.
![IMG_5555.JPG IMG_5555.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30086-2e0a94a8926e1d18f9d43bb5e99a8d64.jpg)
Using the boring bar, I took the cylinders out to size, measuring both with calipers and checking final size with a test bar of the proper diameter. The last few passes were done with very light cuts, and very slow feed rate.
![IMG_5556.JPG IMG_5556.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30087-7993af1453abb65c7458883f08c0f010.jpg)
As you can see in the third photo, the resulting bore was mirror smooth (okay, photo is grainy, does not show it well - tough to get camera to focus in right spot!). The test bar fit nicely in each, if I plugged the bottom of the hole with my finger and dropped in the test bar, it floated down, and I could feel the suction when drawing it back out. Best I've ever had a set turn out - hope I dont mess up later on these!
![IMG_5559.JPG IMG_5559.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30088-c9047c372c129d079a4cc96595ca5112.jpg)
Fourth photo shows the three blocks so far, in front of the manifold in the positions they will be. The steam chest for the left one will face left, and face right for the other two. You can see how the bores are offset to leave more material on the back wall and the steam chest wall.
![IMG_5560.JPG IMG_5560.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30089-2f05b9d55f0920fda30371fce8941c24.jpg)
Next steps were to make the steam passages. Kozo used a 1.5mm mill bit to cut the outer ones - I dont have one that small, so I drilled a series of 3 holes and used a micro bit in my high speed air tool (like a little dentist drill - I use it for detail wood carving) I connected up the holes to make a slot. For all these drilling operations, I set up the first block in the milll vise, using a straightedge to line it up at the edge of the vise. Then, once I had the position of the holes dialed in on the first block, I could swap out to the other ones and get the same result - saved a LOT of setup time (center/measure once, drill 3 times).
![IMG_5563.JPG IMG_5563.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30092-16b0e88725b5f57e9cfce634ab9f8909.jpg)
Next photo shows milling out the passage in the center - that one I had a mill the right size for.
![IMG_5564.JPG IMG_5564.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30093-f4adf56a09335dc5daac0c0556be02fb.jpg)
With the passages milled from the side, it was time to make the connecting passages. All the passages are at 20 degrees, so I set up the mill vise on the tilting table for them. Again, used a straightedge on the side of the vise to position the blocks the same every time so I could set up once and do all three blocks. Again, triple checking that I had the blocks oriented correctly! Started out with a mill to make a flat at the top of the cylinder.
![IMG_5566.JPG IMG_5566.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30094-e216e0595a197c268cc3e3e6a168fe63.jpg)
Then, drilled the passage down till it met the slot cut in the face in the previous step. This was repeated for all three blocks, and at both ends of each block. Due to the offset of the bore, I could do the top hole for number 1 and bottom hole for 2 and 3 in one setup, then readjusted for the rest of the holes.
![IMG_5567.JPG IMG_5567.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30095-6215695267d6f2620d4f6f828e7f5b3e.jpg)
Next up was to make the passage for the exhaust, which comes in from the back wall of the block and meets the center slot. Again, started with a mill,
![IMG_5568.JPG IMG_5568.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30096-cdf2c1234ccf7f4035b32e1762b1dce3.jpg)
and finished with a drill through to the slot.
![IMG_5569.JPG IMG_5569.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30097-b300790ab3822f3fa088fb44ea5ae6f4.jpg)
Last step was to make the steam inlet passage. Unlike many engines where the steam inlet comes into the steam chest cover, for space reasons the Shay has it coming in from the back wall of the block, exitting into the space inside the steam chest next to the valve slider. This was done with another angled hole in the back wall,
![IMG_5570.JPG IMG_5570.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30098-094d2e2527293784024907d7015f25d7.jpg)
and a vertical hole in the steam chest face.
![IMG_5571.JPG IMG_5571.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30099-b0bb8a3ec90ed764bb2cdd07d150f4ca.jpg)
Last photo shows all the cylinders so far. Note how the number one block (on left) is a mirror image of the other two.
![IMG_5572.JPG IMG_5572.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/30/30100-d1053b856c319148331a8df35d66386b.jpg)
Enough for today (okay, some of this was done yesterday) - time to sit back and admire the work so far! *beer* Next up will be to start drilling/tapping all the mounting holes (lots and lots of them).
