Bernd
I'd use a volt meter to check to see if you are getting voltage to the machine first. Check at the terminals at the main disconnect switch on the machine to see if you even have power to the machine.
Welcome to machine wiring 101. Used to do this at the place I worked. Check the fuses to see that they are OK. Should be three, probably Buss Fuses (brand name). You'll probably find them right after the main switch.
Good luck and happy hunting.
Bernd
Bernd
