Chuck, Thank you
- So far it's not that difficult for me; plus I'm learning a lot in the process. Just plain Fun!
Thank you Dean :big: - Ribbit! *beer*
My morning shop time was interrupted by a recalcitrant server at work
- took a good bite out of my fun.
Some done though - including another minor ****oo.
A quick visit to a tire fitment center produced a bag full of tire valves that would normally just be thrown away. Goodie; a freebie!. The staff there were so helpful, that they actually started unscrewing the valves from the stems, but I asked them for stems & all; the stems are nice little brass pipes hidden inside a lot of rubber. It appears that tire valve technology is changing; the type with the long spring favoured by modelers are disappearing.
Here is a collection with three different types I found; the one on the left is the one I wanted a lot of, but only a couple surfaced. The one in the middle appears to be the standard used now, with the one on the right another different design, with a very small spring fit to the top of the pin. I'd like a couple more of those as well; those small springs can be handy.
Oh yes, in case you're wondering why I wanted the valves; it's for bits to make the safety valve for the boiler. The valve cap also came in handy!
I marked, drilled, tapped and loctited in the 2mm boiler mounting studs on the frames:
Then I improvised a water filler adapter and cap from some of the tire valves; removed the rubber from one and turned & threaded it to fit the boiler. I got some "shiny" metal valve caps as part of the haul; a bit of emery and the shiny coating (most likely nickel plating) was gone, and the cap is brass. Didn't take a photo of this though.
Next up was the safety valve; I proceeded to build a ****oo on the bottom bit for it; I first turned & threaded the one side M5 with a 2mm through-hole, then, using a bit of rod with an M5 threaded hole in the chuck, screwed it in to do the other side. That had to be threaded M6. Too much torque, and it broke on the M5 side.
oh: Lesson learnt; try and do the big threads first on a piece like this:
So I restarted the safety valve bottom, big threads first, and took a bit of practice at using the lathe like a shaper to cut gripping grooves on it:
I was surprised how easy this was; back& forth with the carriage with a 2 thou infeed for each pass until each groove was 0.5mm deep.
Today's bits were all fit to the boiler, with some ptfe tape to seal the threads; I also assembled the regulator completely ; just the handwheel need to be made & installed on it. I'm not too happy with the tire cap filler; it does not "look" right, so I'll most likely re-make the filler to look like the safety valve:
Hopefully I'll have a better day tomorrow!
Regards, Arnold
